2012 Equinox 2.4L 150,000 kilometers
My Dad's Equinox jumped timing and bent all the valves, a result from low oil. Clearly putting the engine back together, new valves, seals, gaskets, pistons and rings. Pistons are in and pan back on, now before putting the head back on I have the intake camshaft notch in the 10oclock position and the exhaust camshaft notch in the 7oclock position. Crank key is at 12oclock.
Now my question is should all the valves be closed? Because with the camshafts set to the correct positions, the cylinder 1 valves are slightly opened?
Thank you
Thank you
