2017 Terrain 2.4 ecotec, new timing chain, still p0016, p0011, p228d, fuel codes
51r
hello, great forum, I'm having trouble with a 2017 Terrain, runs fine on startup after a few miles, CEL codes show up.
Thought it was a timing chain, when I opened things up, I noticed the timing chain had not stretched and timing marks were right on point. But replaced anyway to be safe.
Started the car, runs okay, but throws the code. Pulled valve cover back off. timing is still on point, I count 16 outer links between marks when engine at TDC, nothing has jumped. (exhaust at 10 o'clock and intake at 2 o'clock)
I can't figure this out, the reluctor wheel is right where its suppose to be but thats only from pictures. And this thread. https://www.chevyequinoxforum.com/threads/yet-another-p0017-issue-sorry.3752/page-2
P0016 is definitely intake side, so I must have the timing off? But if I move one tooth back, the link count won't be the same. I recently did a Malibu timing with same engine, and the car has been running no CEL's. But that was a clear timing stretch and no start condition. This Terrain runs okay, but still think it’s timing due to all the fuel pressure codes.
Idea's? I'm thinking of changing the cam sensor on the intake side. But should I change the intake camshaft? Since I have p0011, p228d.
51r
Bump for anyone that has any insights.
I plan to change the VvT and cam sensor on intake to AC delco brand instead of the Cloyes timing chain kit
51r
no but will look into this.
i changed intake VVT and intake cam sensor to GM genuine parts, cleaned the reluctor wheel on the cams and so far so good. will report back if trhe CEL returns.
Tico007
Check for moisture in the fresh air PCV tube on the passenger side of the airbox. If you take that out and water comes out you’re blocked. That blockage leads to a host of problems including severe oil consumption and fouled oil.
Write your reply...
