2005 LS AWD WONT START
Deshooter
When you turn the key it does nothing no noises. battery is 100% and tight connections to starter. when you cross solenoid with screwdriver gives great spark and you hear starter spinning like crazy but not engaging to turn engine over. Will A new starter fix this?? Thank You
Difference between no crank and “no” start.
A motor has to crank to start.
You may crank a lot and car won’t start.
Now, you may have an ignition issue
Or fuel delivery issue
Or theft detergent issue
Better to be more clear in thread title.
Starter R&R is easy. And part is fairly cheap.
Difference between no crank and start.
It's a 2025 - under warranty. Don't get much cheaper than that lol
