Who has the highest miles on their Equinox?
TDW1954
142,000 here after a rough start. No major repairs since. I wonder how far I can expect to run before the wheels fall off.
My 2013 had 347,000km when the front differential went and I traded it in. I had just fixed the transfer case and AC compressor and realized it was time to get rid of it. The V6 still purred like a kitten tho.....
scchevelle468
South Carolina
2014 four-cylinder LTZ with 208,000.
Update…After vacation it now has over 212,000.
It’s now mid September and I’m up to 215,000 and some change
SteveG
Between Alaska and Virginia
164,750 miles of mostly Alaskan roads and weather!
It's a 2013 AWD LS Nox with the oil-burning pig of an L4 engine (bad rings)
Over the years, I've replaced the following major assemblies:
  1. Cat Converter (both of them)
  2. A front wheel bearing
  3. Timing chain, guides, and tensioner
  4. A single spark plug ignition coil
Routine maintenance work includes a few sets of tires, dozens of DIY oil changes, two each synthetic differential and transmission fluid changes, one each brake fluid and front brakes. Have run mostly Kirkland Signature FS 5W-30 and occasionally Castrol SN-rated 0W-40. The 40 weight oil makes that 4-cyl engine purr. And with almost 165K miles on her, it's probably the weight I'll use from now on.
Please note that I've greatly reduced the oil change interval to 3000 miles on this 4-cyl Nox. I firmly believe this DI engine cannot handle 5000 or more mile changes ... too much accumulated DI soot exacerbates chain wear.
It's been up and down the Alaska-Canada Highway and all over the Lower-48 states. It's well-used...
Metal Flake
Just sold my 2013 with 153,000. Ran pretty good until the last few thousand miles.
My 2016 just hit 70,000 no problem so far.
Jabit
Putnam county NY
My 2016 has 164K , it’s a daily commuter and get away ride. No oil usage issues, no major repairs, just the expendable normal wear items. Oil changes at 5K, trans every 30k, transfer & differential every 60k. In my book oil is cheap by comparison.
bearbait
2008 LS with 115000. Great truck but rust is starting to kick my a$$.
valdapubby
2005 LT at 326,800 just replaced the ac compressor recently and a coolant tube had a hole in it that's all the big maintenance I've had to do in the past 4 years
Shaggy
Administrator
Admin
Arizona
Wow! Crazy to see all these high mileage equinoxes, especially the ones over 200k! Nice! You guys should include pics.
