- Joined
- Aug 26, 2018
- Messages
- 245
- Reaction score
- 45
Chasing mystery (not obvious) knock. I get a driver wheel well rattle/clunking/knocking sound on washboard roads. Small bumps in road does not seem to cause noise. I changed driver strut assy and it made zero difference. Sway bar links are good. Bushings are good. Ball joint is good. A-arm bushings are good. So, I decided to inspect upper trans mount. Under battery box/fuse block area.
this is pic of 2010 mount. the cast flange is different on the 07-09 models.
