2015 Nox makes clacking sound
vinnie13967
I'll try to post a video here. I've already replaced the ball joint/LCA, cv axle and the bearings were bad so those too. The inner and outer tie rods are good, nearly new. I removed tie rod from steering knuckle to shake and test the rack and pinion and it's fine. The clacking happens not just when steering but also when you hit the brakes and gun the gas. I reached my arm up from under the rack and shook the steering column too. Got any ideas? Frame subframe bushings are good too
Could be the link pins - they are no longer rubber bushings like the old days, they have ball and socket like a tie rod end. Grab em and shake em.
