Tires
Waterford Nana
Wisconsin
I have had my 2025 Equinox for less than three weeks, and on Thursday, all of my tires were showing 31 or 32 PSI. I topped all of them off to 41, which is what is recommended. By that evening, one of them was showing 20 PSI. I took it to the dealer the next day and was told there was something embedded in that tire, and it was unfixable. No replacement tire to be found in the state, so one is coming from out of state next Monday or Tuesday. In the mean time, I am driving on the tiny, rinky-dink spare tire. What are the odds of both of these events occurring on the same day, especially with the car being brand new?Something is not ringing true here. Plus I have to pay for the new tire, minus the $150 covered by the warranty.
TSCONE
New Jersey
Sorry to hear about your tire. That type of damage to a tire is usually not covered under tire manufacturers warranty unless you purchase additional insurance for damage other than manufacturers defects.
As far as tire pressure is concerned, inflate your tires to the pressure listed on the label attached to the drivers door jamb. It probably will suggest 35 psi. The 41 psi stamped on the tire is the maximum psi, not what's best for your Equinox.
Waterford Nana
Wisconsin
41 Psi is what is on the door of the 2025 Equinox LT! I don’t think the pressures were checked before I took delivery. Plus,,they were supposed to put Nitrogen in, which wasn’t done.
TSCONE
New Jersey
Ah ok, wouldn't have thought that would be the suggested pressure but they know best.
As far as the Nitrogen is concerned, I think its just a marketing ploy and they never refill the tires with nitrogen. They just install the valve caps with the "N" on them and tell you they have nitrogen in them.
Sorry, you are wrong. Having worked in tire shops, I can attest to this being real. There are several benefits to Nitrogen over Air, including slower leaks if you get a nail etc, as Nitrogen molecules are larger and won't leak as easily. Nitrogen does not expand as easily, which result in a cooler running tire. Heat is a tire's biggest enemy, so this is very useful.
TSCONE
New Jersey
Sorry if I didn't explain my myself that well. I definitely believe in the benefits of using nitrogen in tires.
What I was trying to say is that many dealerships add things to the price of every car they sell, like pinstripes, door edge guards, nitrogen in the tires and other things like that. I seriously doubt they deflate every tire on every new car they sell and fill them back up with Nitrogen.
Ricklack, how did you get all of the regular out of the tire before adding the 100% nitrogen ?
