Tire Pressure Monitors
Ken Rosey
Edmonton, AB
Just how accurate are the TPMs? I notice mine read about 2psi below the tire guage I'm using. Just wondering which one is correct.
Ken
Z_Ghost
Super Mod
Texas
The cheep ones you get up at the parts store are not that great, they can be off by a few lbs when new and they just get off even more as they get old.
I have 5 gauges and not one of them is the same as any of the other ones.
When I fill the tires I usually have the car running and refer to the screen in the dash as to what the tire pressures are.
jsfb6pts
Petoskey ,Michigan
Tpm
If you rotate your own tires ,each tpm needs to reset be to its new location .
They do mine when I have them rotated .
I wish there was a way to reset the tpms location without using a scan tool... I mean some models have bluetooth so why not...
Z_Ghost
Super Mod
Texas
Should be a way to do it, I know I could on the Cobalt.
The tire pressure +5 -5 psi don't work on yours?
No, To have the position of the tires rotated.. When you have them rotated for the first time. It shows the front pressure on the back and witched from Driver to passenger. So they have to reprogram it so that every tire is matching position to the DIC!
Z_Ghost
Super Mod
Texas
They took that out in 2011 from what I have read.. Bummer
So you just have to live with it as is? With all the wheels messed up on the DIC?
I am pretty sure you can take it into the dealer to have it reset.
08PILOT
West TN
Just had mine done yesterday (O/C and Rotation)
I don't trust the parts store Tire Pressure gauges.
JohnMartyn
Tire pressure monitors are electric systems that keep a watchful eye on the amount of air inside your tire. While I applaude you for paying more attention to you're tires I have reservations about pressure monitors.
Did you have one rub you the wrong way? :p
prheaume
Sherbrooke,Qc
you take a PVC tube, drill a hole in it to screw an air valve like the regular one on wheels. Place the 4 sensors in the tube, seal each end.
Build a 36 PSI pressure in the tube, all your sensors will read 36, the tube is in the back of the truck, no lights, no sensors on the wheels
