Tire Pressure Monitors
mgaz
NE Ohio
TPMS sensors
After switching snow tires, I could do my own with the let air out system. Worked great on my 10 & 12. Won't work on our 13.I bought the scan tool on amazon ($65), works great.
jamesh
I wish there was a way to reset the tpms location without using a scan tool... I mean some models have bluetooth so why not...
Step 1 - Enter leaning mode
Set the gearshift lever to "P"
Put the ignition switch to “ON”
Enter the interface of tire pressure display by DIC
DIC shows "Press Set / Ctrl to re-learn"
Press “Set / Ctrl”
The turn signal is lighted for 3 seconds and the horn beep sound twice to enter the learning mode
Step 2 - Read tire pressure sensor information
Start from the front-left wheel,
Make the J-46079 or EL-50448 TPMS Activation Tool antenna up against the valve core position & close to the rim of the tire sidewall
EL-50448 TPMS Activation Tool starts by the start switch
Successful to read the tire pressure sensor information when the horn bleeps once
Step 3 - Same method to read other tire pressure information
Follow the instuction above to read tire pussure of the front-right, rear-right, rear-left wheels.
Turn signals is lighted for 3 seconds and the horn bleeps twice when the learning is complete.
i successfully reprogram TPMS on my 2013 Chevy Equinox by using jdiag 50448 and buy from amazon @19 bulks hope it helps
