Tail light replacement problem.
RPF
I have a 2022 Equinox. The passenger side rear light is broken. I have tried 5 or 6 different replacements and none work. They won’t light up like the original. I can still use the original so I know there is no vehicle problem. Any ideas?
SteveK
are you speaking of the bulb? Are the bottoms the same as in both single tip or both double tip
RPF
Here’s a photo
SteveK
so not a bulb but the tail light assembly. That is an OEM part. Odd you are unable to source correct one.
Where are you getting the parts? I can't fathom 5 or 6 defective replacements. Should be a simple plug n play - from the pic it looks like the LED version. Only the RS and Premier have LED taillights, LS and LT have non-LED taillights for 2022.
I watched a South Main Auto video recently, where Eric O had a 2018 Equinox in with a tail light problem. There are quite a few RPO codes for the exterior lighting on the 2018+ I wonder if what you are getting is not the right part number? Does everything in terms of connectors and bulbs match exactly?
Big Papi
Time to explore the dark art of wiring including grounds. A test light would be helpful, a meter even better. Don't forget the wiring diagram
RPF
eBay, CARiD, and Amazon. I’m trying rockauto now. They say oem. I’m guessing aftermarket is no good for this. Chevy said that they are having a hard time getting them.
Last year I stupidly backed into a pole and busted my RR stop/turn taillight (and other damage) and it took from July 2023 until Feb 2024 for the body shop to get a new LED taillight. At first they ordered the wrong one (non-LED) but when I checked with the dealer, they had none either. At that time Rockauto was also sold out. Good luck
SteveK
Is there any number on the old and new that can be used in ordering.
It baffles me that a part can look identical and yet be different in operation.
Actually, the parking light/ reverse light section the user is trying to get looks different between LED and non-LED and is easy to see the difference. The LED is one continuous parking light, whereas the non-LED version is broken into segments (2 I think).
RPF
Everything matches exactly
RPF
I ordered nine w from rock auto. It says OEM
Keep us posted on the RA part.
Unfortunately, eBay, CARiD and Amazon tend to be a 50/50 chance of getting something that is not OEM these days, even if it says it's OEM.
Who would have thought something as common as a 2018+ Equinox would be a problem to find taillamp assemblies for. Seems like 2 out of 10 cars on the road is an equinox.
blevtr
Just got tail light assy from Rock auto. It was CAPA approved and fits perfectly. All the low ratings on Amazon spooked me so spent the money and got a good unit.
