Willcruz82
- Joined
- Jun 18, 2017
- Messages
- 4
- Reaction score
- 0
2006 Chevy Equinox LT owner here.... Here we go, So we noticed there was a humming noise coming from the front right passenger side. Also, the dash lights were on for the traction control and the ABS. We changed out the front hub bearing (did the brakes while we were at it rotors pads etc...) and everything was great. the T/C, and ABS lights went away and no more humming.. The new hub bearings fixed the issue. NOW a few weeks go by, and now there is a horrible vibration that comes from the rear, feels like rear drivers side but also a little centered. The vibration can only be described as going over the rumble strips on the freeway. It comes and goes and it happens at various speeds. We thought that this too could be the result of bad REAR hub bearings. So, after fighting to replace them, I got it done (did the rear brakes as well drum pads etc...) However, that DID NOT fix the problem. The vibration is still there. Please if anyone has a fix for this please share. I am limited on funds and would really like to fix the direct problem instead of spending money on parts that do not need to be replaced.
