rear hatch won't open
ron6962
2015 Equinox - rear hatch suddenly will not open with the button overhead inside, nor will it open with the remote, but when I manually press the latch outside, it unlocks, then immediately closes. It never raises. The only way I can open it is to catch it when it unlocks and manually pull it up. Once up, the only way to close it is manually...the button on the hatch does not close it. I have verified the fuses (#23 and #49) are OK. I also Googled the issue and no help so far. Any suggestions on what to check is appreciated. Thanks.
ron6962
Well, this is what I get for trying to help someone with a car problem over the phone. I asked her to try the switches again with the car running and this time when she tried the overhead switch, she said she noticed it was in the OFF position. Honestly, I didn't even know it had an ON/OFF switch. She put the switch to ON (also has 3/4 ?) and all is working normally again. I apologize for the confusion.
Shaggy
Administrator
Arizona
Love those easy fixes!
Pablo20
Southern California
Don't sound defeated! You asked her to do something, and now it works. Well done!
