These are oil pressure control solenoid circuit codes. The first thing I would do is check your engine oil level. Hopefully you've been doing 5000 mile engine oil changes. If all that is good, you could have a bad oil pressure control solenoid, or a broken, corroded or chewed wire or connector to the solenoid.
All this oil pressure control solenoid does is adjust the engine oil pressure to maximize fuel economy. You'll see it toggle from ~65psid down to ~33psig or so at cruising speeds. You should be able to read your actual oil pressure on the center cluster display if you toggle through them. When these solenoids fail, they should fail at full pressure, so you should see the higher oil pressure all the time.
I had this same solenoid fail on my 2015 Chevy Malibu 2.5L. It didn't set a reduced engine power message. Just a the check engine light and code. Mine was a bad solenoid. It was an easy and cheap DIY fix on that car.
