A lower nox
08PILOT
West TN
Torrent springs are available, but in a 2.5"/2.0", no idea
which is front and which is rear. (Assume 1st # is front)
but they are around $330 on the net. I was told lower
than that and you'll have Rear tire wear/camber issues.
(I read about "camber" issues om a Saturn VUE forum)
I still may consider it when it is paid for in 18 months.
PB98LT
florida
did the Nox ever get lowered?
Would like to lower mine just enough to eliminate the wheel gap.
ridin_low07
Has anyone tried it out yet? If I had the extra funds around I would try it out in a heartbeat. I cannot believe the lack of aftermarket support available with these. I will also be looking to do a rear disc swap at some point and time.
05lsawd
Im looking at trying some sort of lower setup, haven't decided if I want to try cut springs or not, I ran them on my old car and the ride didn't suffer that much, im only looking for about a 1-1.5' drop though.
ridin_low07
Here's my Photoshop of what I'm looking into doing. Full air ride set up with xxr 530 18s. Shaved handles and relocated filler neck. May also build some fender flares
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
ridin_low07
with the coils on these cars you cant do that. they have pigtail or ends that spiral into a small. having the coils as such makes it to where if you cut them they will not seat correctly and have the possibility of falling out when going over bumps, at least the rear that is.
EQui
Nice concept. Were you able to build the fender flares? Any updates?
