2025 RS trailer package (Receiver Hitch) (What does it look like installed)
penright
We just bought our 2025 this week and I was looking for receivers that would fit it. I found one on the Chevrolet website.
My question is what does it look like installed?
I can not find any pictures online. I joined this forum a while back, while I was working on my granddaughter's 2017. I was hoping maybe someone has had one installed and would share a picture.
It also says the hitch plug and bezel are sold separately, I do not see them anywhere. If it was something in the refrigerator, I would just ask my wife, I am sure it is right in front of me and I just don't see it.
Anyone with any experience that can help?
penright
Last night, I took a picture of the underside.
I also zoomed in on the bracket
It looks like to me that you have to pull the bumper. Then it slides into the frame rail up to the flange. Then the bumper and exhaust mount goes back on. I am making that assumption based on the threads are on the bracket and there are just 4 bolts with no nuts. The two flat washers with the two holes, makes me think they have to come from the bottom. The flat washers look like it adds support by sandwiching the frame rail between the washer and bracket. I like the way it is connected between the rail and bumper. That adds some support from downward weight, but also rear pull.
The Curt model that I found is a lot cheaper but is more of the traditional method of fishing the bolt through the frame rail. It has 3 bolts but they only hold it against the frame rail.
I still would love to see some pictures. The Curt one was a 2024 model, I think. :)
AmmoJoe
Hi I just came across your post in the weekly email. I have a 2019 equinox (I know you have a 2025 and there is a model change) and I installed an aftermarket hitch receiver. If I can give you any advise it is to go with the oem one if it mounts up higher than an aftermarket using the frame holes underneath. I say this bc the one on my car is very low and I wind up scraping if I have anything hitched up. I bought a hitch riser to bring it up higher but coming out of my driveway I will still scrape the underside of the riser or the bottom of a cargo basket, empty.
penright
@AmmoJoe thanks for the info. I was about 70 toward the OEM. Not sure if it will be any lower, I guess that depends on whether they give a new lower valance. Comparing the pictures it does not look like it.
Now I am about 85% toward the OEM. My only question now is about the valance. The RS has the painted one, I don't want to start cutting on it. I wish could find someone with a 2025 that had pictures. :)
AmmoJoe
On the previous generation the rear bumper would actually get cut and a trim piece would be installed. The part would replace the actual metal bumper underneath the cover.
penright
Thank you, .....
I can see that now, my first thought, it was sandwiched between the bumper, how the hitch sits in front of the flange there is no way. I don't see the trim piece in the photo of the OEM.
Rocky
2024 LT
I purchased a factory GM hitch (84078271). The receiver sits up inside the rear bumper. Much cleaner than any other third party receiver I've seen. It took 2 - 3 hours to install. I found a good video on youtube showing / explaining the work. My bezel trim piece was factory cut and clipped in on the top and screws hold the bottom. Easy to remove and expose the receiver or keep covered when not in use like there is no hitch. The hitch plug was included in the kit I purchased.
AmmoJoe
I like the rear bumper on the 22-24 models with that hitch cover.
penright
Thanks for the picture. That should be the same since 2025 sits on the D2XX platform. I am not that knowable, I just know how to Google. :)
I am guessing you installed your, correct? I am guessing mine is not "factory cut". Am I missing something?
Rocky
This post is for a 2024 LT. I have not seen a 2025. I believe 25 is the start of a new gen body (4?). So this application may not apply to your vehicle.
Yes, I did do the install of the hitch
The pictures of your fascia' don't look like mine. Per the 3 attached fascia pictures. My hitch trim cover was factory cut and screwed in place.
Hope this helps...
penright
Hope this helps...
Very much so. It tells me mine is going to be hard. :) I think GM would have considered that for the new body style. I reached out to the salesman, and he pointed me to a service writer.
The body is new. My understanding is the frame is not and looking at your "Hitch Expose" that part looks the same. Thanks so much for your time in putting this together for us.
penright
With the help of @Rocky pictures, I started calling, first bouncing around Chevy, then a local dealer. Rocky's cutout was a factory cut out and this online video of a 2018 shows him cutting and installing a bezel.
The dealer pointed out the online specs and said the bezel was sold separately. He could find one for the 2024, but not the 2025. Since I don't have enough experience with a new car, especially bleeding edge new, I am not sure if the documentation is behind or does it means it will not exist in 2025 models. Not sure where to go from here, I guess just wait to see if they list a 2025 bezel someday. I wonder how often to check?
penright
My GM friend pulled the instructions for the rear fascia. The bottom line is that the instructions looked just like the Gen 3 in the video.
Something is not right. I hope someone from GM runs across this post. :)
This document has the right year (red arrow) but later on, instructions do not match the 2025 as you can see from my pervious pictures.
penright
Some have asked me about the OE install. I have not done that yet. I would like to but I don't trust the Kit. The instruction pictures do not match what I am seeing. Also, I heard that the connector may not be as expected.
The 2024 has 6 pins and the 2025 has 4.
Can someone who has done who has done both can confirm? I did go back to the 2024 video and stopped it, tried to capture a picture but could not see the pins.
2024 connector from the video
OEM install instruction ...
Enjin
I used the etrailer install instructions for the 2024 (for my 2025). I installed the 2024 hitch on my 2025. The harness has been the issue. The 2025 uses a 4 pin, trailer side Molex part number 33471-0401 while the earlier 2024 Equinox used a 6 pin of the same family. I can't find relays in the 2025 and the fuses are populated under the hood so should 'plug and play'. With the 33471-0401 connected to the 4 pins on the std 4 pin trailer flat conn (like the GM pic in Penright's Oct 10 post) I get no power. One of the 4 pins on the 33471-0401 is ground. I'm wondering if GM now 'code' the hitch power...which would be a PITA.
I did contact etrailer re the same, they advised Curt is aware of the '4 pin issue' and 'Curt T-Connector Vehicle Wiring Harness with 4-Pole Flat Trailer Connector - Preorder # C88RV. ' and the picture of C88RV (as of this posting) on etrailer isn't the pending C88RV. https://www.etrailer.com/Custom-Fit-Vehicle-Wiring/CURT/C88RV.html.
FWIW the 33471-0401 is available on Amazon or Ebay. It's typically used for ignition coils.
