2021 - Front end wobble ??
Brian-Nj
My 2.0 equinox powertrain warranty was about to expire so went back to my local dealer. There’s a new service manager. Took him for a ride felt issue and despite the tsb saying it was the 1.5’s he did my cv shafts under warranty and feels like a different car . All the floor wobbling feeling in floor between 50 and 60 gone .
Rick143
Just an update to this, but it seems the fix may not be the fix. At least in my case. It's been almost a month since I had the CV axles replaced and the wobble/shake is back, but to a much less degree. I noticed it about 2 days ago during a hard acceleration. So weird..
I think ours is starting to do that same thing again also, But like you said to a much lesser degree. Unreal...
RIT333
Here is a few service bulletins on a similar issue.
I would hate to be the helper in. Bulletin 2. Run it at WOT, and held it with the brakes engaged, and then have the help loosen some bolts. Wow, OSHA would be all over this procedure. No thanks , I don't want to be the helper.
I'dluv2
Good thing I saw this thread, I thought it was all in my mind that I felt the wobble. 2020 with a 1.5 it doesn't do it all the time, for me usually between 40 & to mph under acceleration. Going to see the Chevy dealer on Monday.
See what they say. Hopefully the process wont be too painful for you. You may be beyond the 5yr/60K power train warranty, which could muddy the waters a bit.
It's been ~6 months since I last posted in this thread. I'm at about 47K miles now. The only time I notice the wobble anymore, is on the 2nd to 3rd gear up-shift. Unless it's just a particular harmonics / resonance thing, I dunno. Other than that, my Equinox has been flawless. I love it.
I'dluv2
It's a 2020, so technically it's 5 years old (don't know original sale date) but only has 38,000 on it. So I should be good. One thing I'm going to do is unplug the auto start stop eliminator just in case.
Hopefully the original sales date is still under 5yrs for you.
Probably a good idea to put the A/S/S back to factory specs before a dealer warranty / TSB visit.
I'dluv2
Went to the dealer today, warranty is good til Sept of 25. Dropping it off Wed morning and then wait. The service writer had a hard time finding it, even with the service bulletin in hand. Said the reason was depending on which factory, guess there are multiple ones, it came out of.
Yes, I'd have to dig up the TSB for this, but I believe its for the made in Mexico Equinoxs only.
I'dluv2
It's under 5 years so GM gave the go ahead. I should get it back Monday, hoping all parts show up. Funny since it's and AWD there is 1 more part ( not sure what) that needs to be changed.
That's cool that you're still under the 5yr power-train warranty. Lots of people bought their 2020s in 2019. At which point you'd be timed out on the 5yr/60 warranty. I'd be interested to know what the additional part is. For my 2021 1.5, AWD just the two front CV shaft assemblies were replaced. No other parts listed on the work order.
Brian-Nj
My 2020 work listed the 2 shafts and the 2 nuts .
