2015 model burning oil
Deb Bobo
I have 78,000 miles on my 2015 and it is burning oil. My mechanic has cleaned the system, but it continues to be a problem. Is there any recourse?
If it is valve seals, you can buy some rislone valve seal conditioner. If it is blow by, I would look at the PCV system. bad valve or vacuum leak.
Uluz2a6
Valve stem seals can be the cause. Usually it's the piston rings that we see fail. The updated pistons and rings help combat that issue. 90% of the time we end up boring the cylinders 0.020 and using oversized updated design pistons to insure the best outcome
