12V or Inverter Options for Front Passenger?
techDriver
When I bought this car I was shocked that the USB-C was only 40W (something I had to test for since not marked) and there was no 12V DC socket for my 100W AC inverter (or for that matter, just a forward tire inflater if needed). There was enough about the car that I bought it anyways, and I largely love it. Except this is really eating at me. We go on long trips and I or my other half would like the option of working away without having to worry about power.
Is there a safe way to hard wire some sort of AC inverter or 12V (8-10A) socket for the front-right passenger? Yes, I know there's a 12V in the back, but I'd rather not run a wire from the back to the front. Another option I was thinking was some sort of power bank in the little cubby under the centre console.
I'd ideally like to not drill holes, curious if there's a wiring pass-through to the batter/AC I could use that others have discovered. Or maybe there's a reputable after market place I ought to go? I'm in Toronto, Canada if that makes any difference.
Thanks for any advice out there. I'm still kind of shocked Chevy didn't put in a modern 100W PD USB-C option AND took away something so basic as a 12V.
On the first morning after my purchase I went outside to install my Garmin GPS, I like the display better than my Google display. Anyway when I realized there was no plug I was really surprised. Went right to Amazon and ordered a USB to 12V converter. Luckily the 2025 has a great roomy console so the wire doesn't bother me much. I had the same issue with my dash cam.
techDriver
Ya. Those and other low power devices like dashcams should be fine with that USB option. There's also USB power only cables I suspect will work if wanting something more direct for devices that are already USB. I still haven't decided what to do for my needs with a laptop where 40W won't cut it. Anyone needing closer to the 10amps most of those 12v systems provided (to support typical 100W needs) is just out of luck for front options I guess short of some of the other options proposed here. I'm leaning towards a car audio specialist to mount a higher wattage power block though the firewall.
Techdriver, curious how you were able to figure out that the USB-C output was 40 watts. I am not doubting it, just want to learn something for my bag of tricks. Thx
Michael_D
Michigan
Vernal Equinox, Eh? Clever.
Hope I'm not too late to chime in on voltage stuff. Presuming, ( never use the word "assume" )... IF: USB-C, and other USBs typically max at 2 amps,
THEN: 12volts controlled down to 5.2volts, blah, blah, blah.! (The magic circle of volts, amps, watts.)
I came up with being able to charge one phone and run my Dash-Cam safely.
For 100Watts, I strongly suggest running a wire gauge recommended by the inverter you buy,... from the battery (Fused), then through the firewall, (there is so many holes to run wires over, under, around and thru, ) with other wires/harnesses no need to drill a hole......to an inverter, to power a laptop or whatever you want up to the inverter size. Make sure wires can't chaffe/rub to short out.
If I was doing it, I'd use 8Ga. wire. Red and Black.
Lazy Bones
The EV version gets a 12 Volt outlet in the little storage space near the floor between the two front seats, and the one in the back. the EV also has an option for a 110 Volt outlet on the back of the center console. Looks like us ICE people live in the low rent district
Yes, I bought my equinox two days from the Vernal Equinox, so Vern it is.
There is a 12 cigarette plug in the rear but I still sometimes use my Garmin GPS and I was surprised when I realized that I couldn't plug it in at the dashboard without a converter.
