we have been down this road but it is still possible you have a bad vvt or phaser if you did not swap the phasers providing you have the lea engine if not they you cant swap tem easy they can be swapped but the timing is almost impossible to get correct. here is an article talking on this. it is possible the vvt is intermittent and or the phaser. do the vvt first clean the old one and test the ohms, if in spec try it and then see how it works. if not then if you have the lea engine try swapping the phasers and see if the problem moves. you can't operate the phasers by hand but you can with air pressure to test if they move. or you can take them apart to see if the guts are still good. i can send photos of bad ones.
1. Rough engine idle
Proper ignition timing is crucial to ensuring that your engine runs smooth and efficient. When the vehicle is under load, the VVT switch will monitor the engine and send information to the computer to adjust the valve timing as needed. However, when the switch is not working properly, its ability to send accurate data is compromised. Even though this unit is supposed to only work under non-normal driving conditions, it can cause the vehicle’s engine to run rough. If you notice that the engine has a rough idle, specifically if the engine RPM rises and falls from 100 to 300 RPM at idle, contact a local ASE certified mechanic as soon as possible.
I'm thinking I could have a bad phaser. I still have a rattle on start up. With all new timing I think it shouldn't? I can't even get a code now. But it will shake an miss like crazy. If I unplug the vvt sensor for exhaust it will smooth out. I think the rattle is the phaser..we have been down this road but it is still possible you have a bad vvt or phaser if you did not swap the phasers providing you have the lea engine if not they you cant swap tem easy they can be swapped but the timing is almost impossible to get correct. here is an article talking on this. it is possible the vvt is intermittent and or the phaser. do the vvt first clean the old one and test the ohms, if in spec try it and then see how it works. if not then if you have the lea engine try swapping the phasers and see if the problem moves. you can't operate the phasers by hand but you can with air pressure to test if they move. or you can take them apart to see if the guts are still good. i can send photos of bad ones.
An I swapped the vvt sensors again with new ac Delco ones todayI'm thinking I could have a bad phaser. I still have a rattle on start up. With all new timing I think it shouldn't? I can't even get a code now. But it will shake an miss like crazy. If I unplug the vvt sensor for exhaust it will smooth out. I think the rattle is the phaser..
not sure what your telling me are you saying you got a reduced power notice on the car dash? or are you telling me you found out you should have 600 psi for rail pressure and it is at 1100 psi?Got an updated . Reduced power is on desired fuel rail pressure is 600,ish an it's at 1100 is up an down .
Both. I'm getting code p228 and p0089 an p0300. When it misfires now the rail pressure spikes to 1100 an desire is like 6oo. An the rail pressure command falls to 0 degrees. I hit the gas the rail pressure command goes up to 45 or so it stops missing an pressure falls from 1100 to normalnot sure what your telling me are you saying you got a reduced power notice on the car dash? or are you telling me you found out you should have 600 psi for rail pressure and it is at 1100 psi?
I appreciate u sticking it out. An yes Amazon is bad for that. I also put a new oil pump . Just to be safe. An I'm going to do the pcv upgrade. I will have to get 100 thousand miles out of this turd to cover cost an time an the psychological damage it has costed lolglad you got it. i went thru that with ebay parts. so that issue still sounded like a bad phaser to me, but you thought you got a new one from amazon and got a bad one. amazon sucks for getting what you think is new parts. anyway you can get them from cloyes they are gm suppliers. what is bad about amazon is someone got one and put the bad one back the the box and returned it for a refund and amazon just puts them back on the shelf and you go the bad one. i see a lot of that going on. for anyone in the future doing this repair don't use amazon go to cloyes and get new original parts.
anyway it is great that you finally got it boy you had a ton of work to do good for you and lets hope it is a done deal now. one thing is to make sure you keep the oil up as low oil will cause the chain guides to fail faster that a jack rabbit in heat. been there also. for some reason the guides are the last in the oil loop. must be the pressure drop going thru that small oil hole in the guide lube system.
also it may be a good idea to put in a pvc system. YT show a guy taht did this and i did it and it seem to be working. something for the future and warmer weather.
I actually bought this needing a trans. I got one at a yard an hour from me. 60 thousand miles. 125 bucks. I swapped tcm out so no programming. An flushed the lines an use new fluid. I have under 5 grand in the car now. If I get a trouble free year out of it I'll call it A win. An on the oil changes I always go 3 thousand miles. Anything over is asking for trouble on the newer stuff. Maybe why the want u to go so long.it kind of sounds like it. keep the oil level up and change the oil every 3 to 5k for the money you put into it you may want to lean closer to 3k and i told my girl to use good synthetic oil, and if you have not changed out the seals you may want to go with high mileage type oil it is said to have additives to help the seals remain soft and keep fitting the shafts. i changed out all the seals on my girls engine when i had it out. and i did rings and rod bearings. i did not do the mains and the rods looked good and the mains do not get quite the abuse ad the rods do and i did not want to separate that case section. also if you have a ton of miles on the trans don't just change the oil. if the trans ol is black leave it alone. but if you have been up on the trans oil changes you may be ok. the equinox's are also bad on the trans. when they get to 100k the oil in them starts to turn black and that color is the clutch pcs in the oil and if you change it then that goes away and you will be doing a trans soon after. research equinox transmissions and you will see what i'm saying. there is talk on this site about that issue. also the trans oil level is not just a dipstick on most it is taking the drivers side tire off and then going after a plug on the side of the trans. it may not hurt to get in there and do a trans oil level check. just to be safe. and if you have a ton of miles just add any oil you may need. also make sure it is the oil the trans takes do not use any it will work tran oil these trans are fussy.
here is a site for the 6t45 trans if yours is this trans code you may find
here is a YT the clay way to do the trans oil level check
good luck
I have the same problem(2010 chevy equinox LTZ 2.4L 67,00 miles) and just found your thread. Hopefully its the phasers for me also. Like the guy you helped out, i also changed o2 sensors, spark plugs, ignition coil, fuel pressure sensor, solenoids, etc. And Still got a misfire and -15 to -20 long term fuel trim when at idle after driving 10-15mins.ok thanks for the update. it sounds like you have the bases covered. way more than most folks do.
I have a 2010 equinox ltz 2.4L with the same issues at only 67,000 miles.I actually bought this needing a trans. I got one at a yard an hour from me. 60 thousand miles. 125 bucks. I swapped tcm out so no programming. An flushed the lines an use new fluid. I have under 5 grand in the car now. If I get a trouble free year out of it I'll call it A win. An on the oil changes I always go 3 thousand miles. Anything over is asking for trouble on the newer stuff. Maybe why the want u to go so long.
