2015 manual liftgate opening problem
zor
I have read lots of search results and none seem to address the issue I am having, hope someone can help.
When I activate the switch, I can hear the actuator click and the liftgate will move a little but won't open. After repeated attempts sometimes it will open.
When I manually open the liftgate and use a screwdriver to close the latch and then press the switch the latch clicks open.
I noticed that the U shaped bar that the latch closes around is leaning slightly to the right. Is this normal?
Any help would be appreciated, Thanks
rvseverson
Crickets……..a lot of people having this issue but no solutions.
