Stopleak sorta works
C5620A3B-B4A6-414B-BD9C-917A56640DC5.jpegGot another equinox to fix. Head gaskets. Not sure why intake has cooling ports on 1 side. The heads have ports on both ends but not the intake. Assume gm wants coolant to flow in one direction?
Fuel line fitting was stuck. Kept workin at it and finally came loose. And now dipstick tube is stuck in block. Pulling heads is a pain.
This is one from 07/20.
3BACD7B0-7554-4948-BD9B-09C4B5F87328.jpegdone. Well not technically. 94% I suppose.
Got another one. 08/13 Has coolant stains near vent bypass and manifold outlet on driver side. Haven’t seen stains at both locations on any car before. Level in surge tank goes up quite a bit when hot. Has all signs of overpressurization in cooling system.
This is new car. The pics are from old car. That is gone. Have not pulled heads on new car yet
