starter problem
noxmadmax
I have a 06 nox replaced 3 starters after replacing when I start nox it makes noise like switch is stuck and keeps trying to start nox. Does this a few times then starts normal. Then every once in awhile does it again then starter goes out. Can someone help.
vtbigdog
Check the battery connections. Its possible that you have a bad connection or your battery is weak and needs to be replaced. You can have the battery tested as well.
