Something went wrong while attempting to change my low beam headlight on driver side
Kellibean83
I was trying to change my low beam headlight on driver side and after I got the cover/cap off that covers the light I couldn't get a hold of the bulb to remove it. So I thought I should turn my wheel the opposite way so I could see it better.. fyi I didn't remove the fender ..anyway my car started just fine and I turned my wheel the opposite way..still no luck.. well now my car won't turn on. Key won't turn. Steering wheel won't unlock, can't push brake pedal in at all.. but a few times as I was sitting in the car with key in the ignition it actually tried starting by itself. I was not touching the key or anything.. this happened a few times.. what did I mess up? Did I loosen a wire or something that I shouldn't have? As far as I know I never pulled any wires out or moved them. Someone please help 😞😮‍💨
Maybe you battery has a low charge. Can you put it on a battery charger, or try jump starting it?
Vulpecula
Put tension on the steering wheel in the direction it is turned. At the same time, try and turn the ignition key to off and remove it.
