Sensitive brakes
michael4
I have a 2020 Equinox. The brakes are very sensitive to pressure. Is there a way to make them less sensitive? Reprogram the module? or something? It is not pads , lines or shoes. My wife drives the car without a problem , when I drive the brakes lock up very easily as I have a problem feeling them until I put a bit of pressure on the pedal. No problem with my truck just this car. Nice car but the pedal pressure is so light I have a lot of trouble driiving it.
RIT333
Since your wife is not complaining, I would suggest that it is the difference between a car and a truck. There will be a difference. If you drive it long enough, you'll get used to it, and then your wife will complain about the brakes on the truck. Sorry.
