The issue im having is my riverside door lock switch will not unlock any doors, it will lock the doors no problem. The pass. Side does jus fine. Ive taken door panel off and replaced switch but no luck, I checked the wiring and there is power going thru ea. wire when I push it. Im at a lost here, I checked fuses as well, I uncooked battery n waited bout ten min and hooked battery bk up while key was n on position n still nothing, dealer wants 95 doll for diagnostic, o BTW its a 05 nox
