P15a1 code fuse location
johntalipsky
Getting a P15A1 code, Fuel EconSwitch related, suggested O first check the fuse. Can't seem to locate this fuse. Any help??
corvairbob
this has the issue possible causes and fixes no mention of the fuxe. my guess if it was a fuse you would not get that code. as the system would be shut down. so follow the path given on that site and see if that helps you out.
johntalipsky
Thanks, somebody mentioned a fuse but obviously couldn't seem to find any fuse related to this switch
