Evaporator drains are clogged. Moisture in evaporator will give you a strange odor. Clear the drains then run the AC. It may take a while but it will go away.Anyone getting an odor from the AC system on initial startup? Sharp kind of smell, cant really describe it.
Great! And the drains are where? Best way to clean them? 2018Evaporator drains are clogged. Moisture in evaporator will give you a strange odor. Clear the drains then run the AC. It may take a while but it will go away.
located at the bottom of the evaporator box under the hood. just clear the drain but be careful; don't poke screwdrivers through the bottom you could damage the evaporator.Great! And the drains are where? Best way to clean them? 2018
Good tip, Thanks!I bought this back in 2022. It helped for a while I may need to do it again. nextzett 96110515 Klima-Cleaner Air Conditioner Cleaner - 10 fl oz https://a.co/d/d5fWsuo
