My front turn signals won't blink.
Jeffress67
My front turn signals won't work. I've changed bulbs and checked fuses. Rear ones work fine.
Flash
I know you checked them but did you try a new fuse?
cnogga77
Did you ever figure out the problem with this because I’m having the same issues with my 18 equinox. Front signals stopped working. Checked all fuses and bulbs. Can’t figure it out
Jclyde
Both front turn signals not working, fuses ok. I have a 2020 Equinox. Dash shows left and right turn signal indicator failure. Also emergency blinkers not working on front blinkers.
running with wolves
Hey, did you ever figure out what was the cause? I have a 2020 equinox that just started with the same issue. Not the bulbs, not the fuses. Beginning to check relays now.
ravenblack67
Check the wiring at the turn signal and at the body control module. You can get a schmatic from alldata DIY. $20 for one month.
