Looks cool! You should post some links of what you purchase and show us a before install photo. :waytogo:
Sent from my Droid RAZR MAXX HD
not the best idea of mounting the ballast ore relay? every time you will need to take of the engine cover you need to disconnect it. but looks really cool!
Thanks "dietz4ibanez". I did edit my previous comment to add more info. This "add on" should help those without fogs. There is actually another Philips LED DLR with 8 LEDs but the dimensions is just tad too long for the flat section of the fog light cover. It also costs way more even with Amazon.com. For the price (about 180), I'ld rather go for a set of PIAA LED fog lamps which I'm also considering for my next upgrade.
Just got done installing the Philips LED DayLight 4 DLR on the existing plastic fog lamp covers. Since the mounting is at an angle and tilt, the bright beam is not facing full front. This works out since the headlamp DLRs takes care of that while these faces traffic intersections and also specific dark spots at night where the low beams don't cover and at a more outboard beam pattern. This works for me. For now at least. I mounted the relay on that extra piece of plastic on the engine cover. I taped up the wire for the parking light line since I want to keep them "on" all the time.
I call these the "Bug Eyes" mount. I'm sure you can make a rectangular cutout and mount the lights so it is flush with the outside surface but I was on the lazy side that time.
The "before" photo is what I have on my album cover which I used 3M reflective tape to cover the flat section. Bought these Philips at Amazon.com since they seem to have the best price and free and fast shipping. Although they are made in Taiwan, it is licensed and designed from Philips Germany. I just hope they will last the claimed 5,000 hours.
DRL not DLR:emotions122:
HID's in our Nox Sport (08) and I have them in all my
other vehicles as well. Guess I need to get pictures.
:lol:
I didn't even notice!
We are not the typical forum that finds a mistake in a post and then continues to pile drive you into the ground until you bleed your brains out...
Carry on my friend!
I guest that you relocate the DRL or just don't have some them in USA ?
