I have 2011 Chevy equinox lt with the 2.4 four cylinder engine. Everything seems to be working fine except I can not get it to quite sending out p0300 code. I've changed plugs and yes used the AC Delco plugs that it only likes. Replaced coil packs and I've replaced the MAF. I've cleaned the PCV and sea foamed it for carbon build up. Ive cleared the codes. And it seems to come back when Im driving and get the RPMs above 5000. The stabilatrak light comes on too when this happens. Some times the check engine light stays on and some times it doesn't but when it hits high RPM it flashes. Please any clue. Cause it runs fine.
update; ive cleaned the throttle body and its till doing the same thing. Im starting to think it might be a fuel pump issue. any thoughts.
