Input turbine speed sensor
mamapanda727
Hi all I have a 2011 Chevy equinox Lt 2.4 and the code is saying input turbine/speed sensor.... issue is, we can't find where it's located, any advice?
NOX4ME
it's a fancy word for the wheel speed sensor. You didn't specify front or rear wheel so you'll have to do a little investigative work to determine which wheel is affected.
mamapanda727
We do have a bad wheel bearing on the front driver's side, however the car won't move at all it starts up just fine when you put it into gear it does nothing
