Front Passenger Floorboard Wet
eddie104
Hello,
I've done some research and have come up empty-handed with my situation. My wife's Equinox passenger floorboard is wet after substantial rainfall. After removing the carpet, I could see where the water was leaking from. I found where it's leaking, see photo, but couldn't find where it was coming into the car. I have resealed the windshield without any luck. Any help would be greatly appreciated.
Metal Flake
It’s a blocked A/C drain tube.
You can reach it from under the hood on the firewall. Look on YouTube for a video to see how to locate it. Just remove and clear it out. Easy 5 minute fix.
eddie104
Thanks for the reply. I have checked the AC drain and cleared it. That did not resolve my issue. The leak happens after I run a water hose on the roof of the car for five or 10 minutes. A picture is below.
eddie104
I run the water hose along the passenger side, and that is when I found the water coming from the corner of the floorboard. I have resell the windshield without any success of stopping the leak.
Roc496
Check the headliner I’m sure it’s on the pass side for stains probably coming thru roof rack on roof
