2019 Equinox AC condenser drain tube location
Austinm
Can anyone tell me or show me where the AC drain tube is on the 2019 equinox? On earlier models it was in the engine bay with relatively easy access but I cannot find it on my car. I have a bad odor coming from my AC even after replacing the cabin filter. The car only has 16,500 miles. I want to use a canned condenser cleaner to flush it. Any help is appreciated. Thanks.
About the middle of the Firewall 18" down from the top. Have to lay on trop of Engine to reach but use a mirror to locate,
CoolDad
I used one of the kits where you drill a hole in the air box under the dash and south a cleaner in. That really seemed to help. I am probably due for another cleaning soon.
Joe m g
The white tube comes through the floor of the car. Go under the car by the driver’s door and look for the white tube next to where the heat shield attaches to the floor. It is almost to the centerline of the car.
Mojackets86
Marysville Ohio
Late response here - for my 2019 equinox premier, floor jack, jack stands and a creeper were used to get safely under car. In middle underside about 8” back from where front door hinge at. I did cheat and removed the passenger center console panel and followed the drain line. Used the evaporator spray in conjunction with the other spray at the intake area. So far so good(2 weeks after this procedure we still have no odor )
