2012 Equinox 2.4L MAF No Signal help needed
emzornes
I have a 2012 2.4L that has a MAF code that I can not track down the problem to it. I have replaced the MAF sensor, pig tail, checked wiring and what fuses I thought went to the system. I have had it started and running and unplugged the MAF sensor and got no change. I have also watched it on live data on a scanner and it reads 0 99.99% of the time but sometimes it will show a reading and then just go back to 0. Is there anything anyone can think of to check other than maybe the ECM. Do these have ground wire issues or other wiring issues that could be causing the problem. Thanks for any and all help
jjs17
Is the replacement MAF sensor OEM or aftermarket?
I won't say all aftermarket sensors fail right out of the box, but you might want to test the "new" one. New stands for Never Ever Worked to some of the mechanics i watch.
Just sayin.
