2010 Equinox LTZ V6 - Catalytic Converter (Back of Engine) Replacement Procedure
webdawg
I did. But I could get no one on any Equinox forum to help me interpret my O2 sensor readings.
I tried an O2 sensor change just to see if it would help, but that did not work. Everything that I have read has told me that A P0420 code 99 percent of the time means bad converter. In this case, it was a bad one.
I ended up getting the converter replaced.
No one wants to predict the P0420 code for any vehicle. Even with the really nice mac tools scan tool that tells you the very first thing to replace on any other code doesn't give you a suggestion for P0420. The reason for this is the scan tool has never been wrong but in this instance it knows that this code "could" be a O2 sensor, cat, MAF sensor(cleaned.replaced), bad re-oil on a K&N air filter, there's just no telling.
I would have started with the cheaper option, like the O2 sensor that can be cheaper than replacing the cat.
Got a Honda Accord that belongs to one of my employees and he has this code, just replaced the cat recently!
