2010 Chevrolet Equinox: Orange/Red Liquid Leak on Front Passenger Side
relunner4th
Hello,
i want to start with stating I'm not the most car savy person
i recently noticed an orange red liquid leaking from my car. I got under there and it looks like it's on the front passenger side right next to the wheel control arm. Looking under the hood i don't see anything, only from the bottom.
After taking a short drive i do notice a slight sweet burn smell like maple syrup.
To the touch the liquid is oily but i didn't notice a smell.
Any help or insight is appreciated.
2012Equinox2.4Turbo
That looks like DEXCOOL (engine coolant) leaking from the radiator hose on the passenger side at the engine or radiator. I have seen many start leaking at the hose on the radiator side, and these hoses need to be replaced after time as they become hard and don't seal without having to really crank the clamp. I marked the hose in yellow for you. I'd start there.
TopHat
Does look like coolant leak. After fixing your leak, you might consider flushing the system and replacing the fluid if it has been about 5 years since last flush.
Michael_D
Michigan
For what it's worth, I also agree that it is coolant/anti-freeze. Leaks also happen on new vehicles. I suggest checking all of the hoses and lines for heating and engine cooling.
Sometimes they simply need to be tightened.
TopHat
Agree coolant leak, but this looks unsafe to me. What's going on here?
Metal Flake
Probably the water pump. If it is, have timing chain replaced too while you’re at it, if it has not been done yet.
