12 volt Power outlets
wlachney
Auburndale,Fl
2012 Equinox LTZ it seems that all the 12 volt power outlets in the car shut off with the ignition, is there a way to get at least one of them to stay powered up with the ignition off, so I can charge my phone when away from home?
TheDarkKnightKnox
Columbus, OHIO
I know the center console 12V outlet works when the car is off, i've been able to charge my phone while the car is off. The Owner Manual also gives a little bit of a hint.....
Notice: Leaving electrical
equipment plugged in for an
extended period of time while the
vehicle is off will drain the
battery. Always unplug electrical
equipment when not in use and
do not plug in equipment that
exceeds the maximum 20 ampere
rating.
