'08 Nox doors wont lock/unlock
Soflonox
Has anyone else measured the voltage to the actuator? I am having similar issues with all four doors and am going through the electrical connections before pulling the actuator. I measure ~5 volts at the driver's door and the same at the fuse panel (fuse 8). This seems low to me, as the other circuits from the panel are at full voltage. Can anyone else verify the voltage for this circuit? In the meantime, I am chasing the grounds.
c927hris
Mine has the same issue. Check the wires on tje driver side door the wires break almost ALL my wires were broken my driver aode window and locks wont work until i fix it. You need a new driver side wiring harness if they are busted as reconnecting wires is not recomded as it seema equinixs are subject to electrical problems but if you are experinced go for it!
