Add Wireless charging to 2025 LT
blingen1
Has any one tried adding wireless charging to 2025 equinox? I found the charger part but do not know if additional parts needed or if programming required.
2025blackout
It works fine for my daughters iphone, but with that said I don't know what she did to make it work but she told me it "was just some settings in the screen". Kids these days I'm finding out are way ahead of most older adults in the tech savvy area with stuff like this.
Jeff D.
Blingen1, my wifes 2025 Equinox LT came from the factory with the phone charger built into the front of the center console. A tray the phone stands verticle in. At first I thought it wasn't working, but if I removed my phone case, it works just fine.
In my Ford, I do not need to remove the phone case and it still charges fine.
Does your not have that built in, or is it built in and just not working?
blingen1
When I got the car I was not able to get the convenience package II that includes the wireless charging. I pulled out the rubber insert and see there is a place to install the wireless charger part. The part is under $100. Checking if anyone has bought the part and tried installing it.
ap19063
I'm going to assume that it's not just a hole... so you see wires? Does the 100 dollar part have wires/harness? Does it have some sort of port where it clicks in? Regardless, I say get it done. For me, it's one of the few nice things in this car. Also, for the member who has a problem with the phone case... I use a military drop level case on my phone and I have no problem charging. Maybe you need to revise that chunky case 😉
ap19063
Pen... just to be clear about what you said. You rest your phone sideways (landscape). I think this is the way it is intended. I have not tried charging the phone standing up.
Jeff D.
I'll try laying the phone down sideways next time. My phone case isn't too chunky, but does have a SP Connect mount built into it for my motorcycle, so that does add some thickness. It's suposed to work with chargers though? Probabaly the wrong orientation of the phone is the issue I had.
Thanks all!
SjM486
2025 Equinox LT. I lay the phone in on it's side with a case on and it charges fine. When it is near 100% I stand it up and charging stops.
