I'm looking for someone to confirm if removing the SD card in a 2020+ Equniox causes the USB ports for Android Auto to become disabled. For instance, I'm recovering the error (started intermittently, now it's constant) and the USB ports under the card to not power devices, nor is there a data connection for Android Auto. The lighting around the ports will flicker once every five seconds or so I'm a never-ending cycle. Does this happen if a card is removed from any vehicle or are these separate issues?
I'm also wondering if it's worth seeing if a dealership will let me swap sd cards with a vehicle on their lot just to see if it the condition above happens or if the problem resolves on my vehicle (that is, are the cards formatted for use in one vehicle only?)
Thanks,
Dave
Thanks,
Dave
