2021 - Front end wobble ??
Rick143
Hey guys, Our 2021 Equinox LT has just started an intermittent brief front end wobble when cold. It happens when accelerating from a stop, Its very brief maybe a few seconds then goes away. It will not do it when warmed up. Its in the entire front end and steering wheel, Feels like the wheel is going to come off for a few seconds then its gone. It doesn't happen all the time.
Hey Rick,
Did you get anywhere with this. I wonder if it is the tires. They "flat spot" from sitting in the cold and then when warm they smooth out.
Rick143
Its not that, because its fine in the beginning then it just comes out of nowhere and shakes bad for about 2 or 3 seconds then its gone. This only happened a few times when it was very cold out first thing in the morning.
Here is a few service bulletins on a similar issue.
  • MC-10209119-0001.pdf
  • MC-10205551-9999.pdf
Rick143
Yes thanks ! That first file you posted is my issue, I have made a service appointment but have to wait about a week or so to get in. Should I print out that page and bring it with me ?
Brian-Nj
My 2020 does it very slightly . Gm has this problem for years with various models . I have a 10 year old Buick that did it pretty bad when i first got it . Dealer kept telling me they couldn’t find nothing despite the tech feeling the wobble in the floor . So I did research on my own found a tsb covering the issue . Told service manager he told me there were none . Printed what I found online brought it to dealer and mysteriously the next day they ordered 2 updated axle shafts . I will say in that car it got 99% better after they replaced them . As far as my 20 equinox I do feel it but very very slight .
Rick143
I would assume they have the service bulletin, but it wouldn't hurt to take a copy.
Dropped off my vehicle this morning and left them with that bulletin you posted. The dealer just called me after looking at the vehicle and said they are going to replace the 2 front axels ! Thanks so much for posting that, It was a Huge help !!!
Brian-Nj
May I ask if they did it under warranty? If so was it the bumper to bumper? Or powertrain? I only have powertrain coverage left and don’t want to waste my time with them if they won’t help me but my 2020 lt 2.0 does this
Brian-Nj
Thanks for info on service bulletin. Took to dealer and my axels were replaced
Hi jr1949 , what year engine and mileage did you have ? Was it it done under bumper to bumper or powertrain warranty do you know ?
JR1949
2021 vehicle with 13,500 miles. It was totally covered by warranty.
Jinxed
Texas
Check the battery sensor module first then battery and alternator. It sounds like power is being diverted away from your electric steering. Could be a few other things but check those first
JR1949
Mine did the same thing. Replaced both front axles and shimmy went away. Fortunately mine was under warranty
Brian-Nj
Mine does it but I have the 2.0 and the tsb I showed the service manager shows for the 1.5L. I still have powertrain coverage and bumper to bumper is expired so they are like they want to be paid for tire balancing and diagnostics . I know it’s the axles but being tsb don’t cover 2.0 I’m gonna get screwed. I had a 2013 Buick verano that did same exact wobble sensation and there was a tsb on that and they replaced axles and it went away . Service manager said no tsb covering 2.0 FWD Lt .
