I recently saw an ad and had info sent from a local indy ceramic coating company. They have different pricing for CUV and SUV but don't specify what they consider the Nox to be - technically it is a CUV but I'm betting they charge as SUV. These are in CAD:
Cars and CUV's:
- Optimum Paintguard 3-year coating $999
- OptiCoat Pro permanent coating $1350
- OptiCoat Pro "Plus" permanent coating $1500
SUV's and Minivans:
- Optimum Paintguard 3-year coating $1150
- OptiCoat Pro permanent coating $1550
- OptiCoat Pro "Plus" permanent coating $1700
Process typically takes one day to complete, ready the next morning.
Warranties are valid for model years 2018 & newer, 2013-17 are eligible for a 2-year warranty.
- Optimum Paintguard 3-year warranty
- OptiCoat Pro 5-year warranty
- OptiCoat Pro Plus 7-year warranty
1. We wash your car.
It’s important to remove grime, loose dirt, and debris from your car’s surface before we continue with the rest of the process. We use a rinseless wash that is gentle on the paint, yet very effective to get the vehicle clean.
2. We decontaminate the paint.
While washing the car removes most of the surface impurities, there are typically many contaminants, such as brake dust, grime, road tar, tree sap, or oil still present on the surface. Some of these contaminants might have also penetrated the paint and bonded with the clear coat so we use chemicals and clay bar to remove such bonded substances from the clear coat.
3. We take your car through a single-stage (or two-stage - extra) paint correction process depending on the condition of the paintwork.
Once the paint is now fully cleaned, we are ready for polishing. When there are imperfections on your car’s paintwork, light does not reflect evenly off your car. There could be light scratches or twirls that could get locked under the ceramic coating, further accentuating a dull, hazy look. During paint correction, we work on the clear coat of your car to remove such imperfections.
We polish the clear coat to give you a high gloss finish, using various grades of polish and special tools as necessary.
4. We prep wipe the entire vehicle, to ensure proper bonding during the coating.
This completes the preparation for ceramic coating!
5. We apply the ceramic coating.
This is when we apply the layer of ceramic coating for your car. This is a thin, transparent layer that bonds to your car’s paint, forming a protective shield. The ceramic coating uses nano-technology, which means that the particles on this layer are so tiny they seal the pores, making your car’s surface water-repellent, and also guarded from UV damage, chemicals, extreme heat, and to minimize scratches.
6. We apply the top layer of permanent ceramic coating (OptiCoat Pro Plus).
As the last step, for OptiCoat Pro Plus customers only, we apply the top layer of permanent ceramic coating for even higher gloss and hydrophobic properties.
