Transmission filter
Tx12nox
I am having a hard time finding out where the transmission filter is located.. Do I need to drop the pan to locate it? I can find many discussions on the fluid change which is not my issue. Simply just where the filter is located.
When I was about to order it on rockauto it said it would be need to be disassembled?
It has been shifting hard on occasion and also shifts hard into reverse with a loud clunk
2012 2.4l automatic
Cliff
Central Iowa
Trans filter is only accessible if trans out of vehicle. Changing fluid only option. Do a complete fluid change every 40- 50K max and should be fine.
