jackallison
Hey, have seen a thread or two about this but nothing consistent. Did the trans fluid at 96k, and have done everything i have gathered from multiple videos and forum posts. 2015 2.4 LT FWD, drain fluid, row through gears while draining, then fill while engine is running. Only took about 3.5 liters (3.7qt, bottles are in liters) until it started to spill out of drain plug. Have heard full capacity is 5qt but lost on if i should top up the rest, or just leave it. If it matters, I got the motul atf-vi, approved dexron vi, it was $9 for 1 liter at summit so I snagged 5 but only ended up using a little over 3 bottles lmfao. Thanks !!
