Tire Size Options
chevy-nana
Hi, Has anyone run slightly bigger tires on their Nox? Ours is a '13 LT with 18" rims. Stock tire size is 235/55/18. I was thinking of bumping up to a little taller and wider tire: 265/65/18, but wanted to know if anyone had tried anything like that and whether it effected turning radius or anything else.
Thanks for your help!
Shaggy
Administrator
Admin
Arizona
You could but there always could be the risk of rubbing, meaning the tire would hit some of the wheel well. I've cut some of the plastic off on my wheel well and that helped alot.
pallettman
That is quite a jump. Your new tire would be almost 3.5" larger in diameter. There are several web sites that will compare tire sizes for you. You will also have to deal with incorrect speedometer readings.
Here is one site I use. https://www.tacomaworld.com/tirecalc
Vondoman
I hv a 2020 Premier (19”) & wanted to go one size wider. I wish I could put one on & check clearances & stance.
Suggestions?
2012Equinox2.4Turbo
I run 20" stock wheels and tires from a 2010 Camaro SS on my 2012 Equinox. 245/45 R20 in the front; 275/40 R20 in the rear with a 5x120 bolt pattern. Very close to stock height but much wider and no rub.
The tire calculator at tacomaworld is great. Best to try and keep height as close as possible or you'll have to recalibrate your speedometer.
Quicknight
I have a 2019 Premier FWD and I need new tires. Wondering if I can go to 255/55/19 from 235/50/19?
Vondoman
I also have an equinox with 19 inch wheels and I was wondering if I could go to a 245 or 255 let me know if you got any answers to that I can’t seem to find them on the thread but give me a holler back if if you do and I’d love to go see how they look at tire shop before I buy a set
