NathanielObi
- Joined
- Aug 29, 2022
- Messages
- 3
- Reaction score
- 0
Greetings All,
So onboard the car there’s a tire pressure monitor that tells you how much psi is in your tires, and it could fluctuate up and down depending on temperature or altitude. But the recommended PSI according to the tag by the door should be 34 PSI
So the problem is…
The PSI on the dashboard says 34psi but when I check with a tire pressure pen straight from the tire it clocks in at 37psi.
Question…
Which one should I go with? The dashboard indicator or the tire pressure pen?
Are they really out of sync? Can it be reprogrammed?
So the problem is…
Question…
