Help appreciated. 13 Nox 3.6
All my problems started after replacing front calipers, passenger side was dragging so I replaced both calipers and hoses with oem parts from dealer.
bled all four corners myself - spongy
Bled again with a helper - spongy
Used a scan tool for ABS bleed - spongy
Upon further investigation I noticed a leak behind master cylinder so I replaced it. Bench bled it before installing.
Repeated brake bleeding procedure again and again still have a spongy pedal
Ps. Brakes pedal didn’t go to floor before
