Rear glass washer not working
Deshooter
I just replaced washer motor cause it wasn't working. The front is now working but not the back. You can hear the motor when you engage the front washer but I don't hear it when I engage the rear washer. Any help is appreciated
Deshooter
I figured it out
Deshooter
I just hadn't pressed it and held it long enough I hadn't heard the pump before but it engaged then eventually started putting fluid on back glass once I held it for a bit
If you don't use the rear washer on a car for a bit, the fluid tends to slowly seep back into the reservoir. So you have to hold it longer to get it working again. Even longer when if it had run dry.
