Problems with 2025 equinox
shlogold
I’ve had my 20025 Equinox LT for about 2-3 months. I bought it used from a dealership with 1,200 miles on it since it had been used as a loaner car. Since then, I’ve put roughly 4,000 miles on it, including several road trips. I’ve run into a few issues and was wondering if anyone else has experienced these or has some advice:
1. Fuel Economy: On road trips, I’ve been getting around 27 mpg on the highway, but in the city, it drops to 16-17 mpg. I do drive somewhat aggressively, but I feel like 10 mpg below the advertised figure seems excessive. Is this normal?
2. Wireless Android Auto: When I use wireless Android Auto, it connects, and music plays for about 3 seconds before disconnecting. It then reconnects and starts again. Is this a common issue?
3. Wired Connection Issues: If I plug my phone in to charge while using Android Auto, it automatically switches to the wired connection. However, the next time I get in the car, it messes up my Bluetooth and wireless Android Auto connection. Is there a way to fix this?
4. Launching Android Auto: When my phone connects via wireless Android Auto, it doesn’t automatically launch on the screen. Instead, it stays on the home page, and I have to manually press the Android Auto icon to launch it. Shouldn’t it launch automatically?
5. AC Controls: When I change the fan speed on the AC controls, the screen doesn’t show the current fan level. The only way to check is to manually open the climate control app from the home screen. Is this how it’s supposed to work?
6. Auto Hold Feature: Is there a way to make the auto hold feature stay on from drive to drive, or do I have to manually turn it on every time I get in the car?
7. Google Assistant Confusion: When using Android Auto and I say “OK Google,” it uses my phone’s Google Assistant. But when I press the talk button on the steering wheel, it uses the car’s assistant, which sometimes gets confused. Is there a way to make this more seamless?
8. Spotify Issues: When I play Spotify through Android Auto and then switch to the Spotify app on my car, and vice versa, the car seems to get confused and won’t play from either. Is there a way to make Android Auto and Spotify work better together?
9. Wireless charging: the wireless charger also deosnt work through my phone case and I have a fairly slim case.
10. When I am using maps or waze regardless if on Android auto or the cars apps, on the dash I only see directions on the right side and don't see my music, is there a way to change that or toggle through different stuff on the right side of the dash?
11. Power Light: Not the biggest deal but the power light for the infotainment systems deosnt dim at night and could get annoying. Is there a way to fix that?
Thanks in advance.
PAequinox24
I have had nothing but problems with my Samsung S23, Android Auto, and not being able to hear notifications on my phone while driving. I have a 24 RS. There is someone on here that can help you. Search and you will find it. He posted a lot about this recently. Good luck. I am thinking of switching to an iPhone....have had an Android since 2010. Switching phones is cheaper than a different car....
shlogold
I have a s24 ultra, once it connects the second time it works fine just it frustrating that it connects and disconnects, and that android auto deosnt auto automatically launch🤷‍♂️🤷‍♂️
