Here is a little more information. The transmission did work before the motor blew. Once the motor was replaced the mechanic said the battery was dead and the Equinox did not have reverse. He said it was possible it was the battery which is what I assumed since that was not the issue going it to this. I go to pick it up and he had not installed the battery until I leaving. He insisted the tranny was bad. I left the lost and once I got on the rode it would not go more than 20mph and after a few minutes the check engine light came on. P0016, P0420, and P0700(MIL Request). But the issue is besides the obvious is I do not think the mechanic cleared the codes after the engine swap. I cleared the codes and let it run for 20 minutes at idle then drove two blocks and brought it back no check engine. The mechanic has his money from the place that warrantied the motors so I am sure that I an sol on that. I checked the fuses under the hood last night and did not see anything.
